Questions about my 9" swap
Old Jun 4, 2002 | 11:53 PM
z28newbie's Avatar
I got a Ford 9 inch from Moser and have access to the tools necessary to set it up so, I'm gonna give it a shot. I do have a few questions, and thought they might get answered here:
Pinion Preload Spacer:
It is a solid spacer and shim pack, and I have nothing to use for reference. Should I just use a crush sleeve first, to get desired preload then "mic" it for thickness and transfer the measurement to my spacer and shim pack?
Thanks in advance for your time...
-Jason
Old Jun 5, 2002 | 06:42 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I just used the crush sleeve. I torqued the pinion nut until some drag was felt spinning the pinion gear, 20 in. lbs. I used the Ford service manual as a guide when assembling. I don't know if Moser uses a different setup or not, I would give them a call if you are not sure.
Old Jun 5, 2002 | 07:25 PM
z28newbie's Avatar
Thanks for the info.
Yeah, ususally when setting up the 9 inch, they say to use the "old shim" for reference when building up your shim pack, but I guess I will just use a crush sleeve, then use that for my reference point.
Thanks for the response...
-Jason
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
