rear end questions
Old Jun 6, 2002 | 10:44 AM
HenryC's Avatar
rear end questions
Howdy all,
I have an '89 firebird w/ a stock rear end (open diff, 2.73 gear...), however I recently swapped a T5 into the car, which came w/ a 3.08 gear set stock, because my rear end is higher it makes the car crawl from a stand still, so I need to replace my rear end gears. However, I would also like some form of limited slip rear end, because the open is unacceptable, (Especially in the rain). However, I really do not want to mess up by spending lots of money in parts I can't use or cause problems, so I was wondering a few things:
Everybody says to just "buy a used rear end", because trying to change the diff. and the gears is supposed to be mroe trouble than its worth. (especially since I have an '89 so I don't knwo how many splines my rear is). If I bought a rear end w/ a limited slip unit in it, how easy is it to install? The gearing that I want, would be 3.43 or 3.73, which is common in 4th gen cars. if I find a used 4th gen rear end is that a bolt-in? Will the torque arm line up and everythign? How a/b my wheels, will they still bolt right on? If this is not the case, then Iw ould rather not get a 3rd gen rear end, because I'd rather not use really old parts, so could I just buy a posi and gears?
Sorry for all the questions, I've just been saving them up for awhile and decided to finally spit them all out
Thanks for reading this far!
-- Henry
Old Jun 6, 2002 | 11:21 AM
ede's Avatar
ede
4th gen rear will bolt right up, easiest thing is to run 4th gen wheels, not sure whatit's take to run your wheels, or go aftermarket
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
