9 bolt posi not working
Old Jun 6, 2002 | 09:34 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I had some new gears and a used 3 series posi installed into my 9 bolt. I have just over 500 miles on them. It seems to be set up right( I had it done professionally) .
I don't seem to have a very healthy posi though. if the car is on jack stands both wheels turn the same when you spin one, or the pinion.
I noticed this morning that I only leave one black mark when doing a burn out.
Is there a rebuild kit for this posi? Is it possible to use the parts from my working 2 series carrier?
How hard is it to remove and reinstall the carrier without messing up the backlash?
Thanks for the info.
Kory
Old Jun 6, 2002 | 11:55 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Sounds like the cones are bottomed out in the housings.
I offer brand new OEM quality series 3 posi's for 445. I also offer a core exchange for used/wornout carriers. Email me with what you have.
Miles
Diff Solutions
Old Jun 10, 2002 | 09:31 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I was having same problem after I installed my "new" used posi. First I just put some miles on it cause I did'nt know how long it was sitting. Make sure you don't back out of the driveway and then get on it, cause more than likely it will be unlocked after you have turned the car so it will only burn off 1 tire. I'm still having trouble at the track cause they moved the burnout box closer to the staging lane so now you basically turn into the box. I look kinda dumb cause as soon as I pull in and straighten it out, I'll back up about 8-10' then pull back in so posi will lock back up.
Old Jun 10, 2002 | 10:58 PM
wuter's Avatar
there is a tech article on how to fix it, from what i understand its not that difficult to do.
https://www.thirdgen.org/newdesign/t...tservice.shtml
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
