Did I forget anything before I start my swap?
Old Jun 14, 2002 | 10:50 AM
88redxtsy's Avatar
I'm swapping my 1988 10-bolt T/A drum rear for a 1988 10-bolt disc rear. My drum rear has 3.08 gears(no posi) and the disc rear has 3.73 gears(with posi). I searched the board, viewed the tech sections and wrote up a checklist. All I'm asking from all of you is to check whether I've left anything off my list and to give me your own personal 2 cents on this swap; Pro's/Con's, tips, advice.
Here's my list:
Gm additive
Gear Oil (Synthetic or non - can't decide)
1 Pinion seal
2 Axle seals
2 Calipers
2 Rotors
1 Set of performance brake pads
Master cylinder and Proportioning valve from '86 4 wheel disc T/A
Complete emergency brake cable set
So that's my list. How does it look? Did I forget anything? Let me know and thanks in advance for your inputs.
Old Jun 16, 2002 | 10:08 PM
Rustynutz's Avatar
Might get some brake fluid, shop rags and hand cleaner. :lala:
theshackle
Mar 5, 2017 06:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
