Help, shifting too late
Old Jun 16, 2002 | 05:27 PM
Rage13's Avatar
Car: 89 Firebird
Having problems shifting. After pressing the gas pedal to floor the trans started shifting at 3000rpm, after trying to adjust tv cable it began to shift at 3500rpm. So far adjusting it either way makes no difference. Any ideas? greatly appreciated
Old Jun 16, 2002 | 09:50 PM
Rustynutz's Avatar
adjust the cable the right way and leave it, then adjust shift points by messing with the governor.
Old Jun 16, 2002 | 10:31 PM
Rage13's Avatar
Car: 89 Firebird
ok, thanks :hail:
Old Jun 17, 2002 | 01:57 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Exactly.
Old Jun 17, 2002 | 12:33 PM
transfixleo's Avatar
First make sure you adjusted it correctly:
To adjust the TV Cable skip the book method and do this: Press the 'D' shaped lock button on the adjuster and loosen the cable setting (The black housing that the metal cable is in will move forward). Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the 'D' button and pull the cable casing (the black tube) back as hard as you can (putting maximum tension on the metal cable) and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable casing so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Numbah-1
Oct 2, 2015 08:27 AM
mfp189
Sep 27, 2015 09:25 AM
