Trans bolts What Size? Also Th400 Questions?
Old Jun 20, 2002 | 11:39 AM
DFIance's Avatar
K I lost my trans bolts, what size and length do I need?
I am putting a Th400 in, will the stock tranny lines work? Also someone said that banging on the firewall is required to get the bellhousing to fit, I have never heard of this?:lala:
Old Jun 20, 2002 | 03:16 PM
ede's Avatar
ede
which bolts? the bolts for the bell are 3/8"-16 and the trans mount bolts are either 7/16 or 1/2 NC the oil pan bolts are 5/16"-18. i think the lines are the same, i think "they" meant dent the fire wall for clearance, i doubt if you need to i think the 700r4 and th400 are the same size case. what you doing with the torque arm?
Old Jun 20, 2002 | 04:11 PM
EvilCartman's Avatar
Car: '82 Z28
When I did the swap from the 200c to the 400, the cooler lines lined right up and threaded in fine. Didn't have to pound anything to make room
Old Jun 20, 2002 | 05:57 PM
DFIance's Avatar
I have the Sphon T/A kit and C/M.
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
