shift kit
Old Jun 21, 2002 | 10:17 AM
camaroluv's Avatar
shift kit
I have a 700 4-r tranny with a shift kit. not sure what the name brand of shift kit. Here is my question. can a shift kit cause your transmission to slip? my tranny is slipping when shifting into second gear.
Old Jun 21, 2002 | 01:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well before Leo jumps on you, Trasgo owns the name "shift kit".
It's more then likely a misadjusted Tv cable assuming you mean slipping as in takes a second to pull in third right after the shift. Go to the tech articals and look for the artical on adjusting the TV cable, adjust it like the directions say and give it one extra click for good measure. One extra click helps especially when the cable is streched and still falls into the line pressure limit.
Old Jun 22, 2002 | 09:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
as long as the throttle blades can open fully without cable preventing that form happening asnd cable is tight at WOT then it should be set right,.
good luck
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
