attn rb83l69
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
attn rb83l69
i had new posi/gears installed in my rear and now it makes clunking noises theres alot of play on the pinion, can i tighten the pinion nut or will this affect the gear pattern?
you shouldn't ask for someone by name when anyone could answer your question. if you really have something for rb's eyes only try the PM or e mail. i bet i could of helped with this one as well as a lot of others
Car: 1986 Camaro SC
ok sorry just that i was talking to him about it before, your right i could have sent a pm
rb has been working out of the country off and on for a while so it may of been a bad idea asking for just him. any way about your problem, how to you know the pinion has a lot of play in it? did you set the pinion depth? did you set the preload on the bearings? back lash ok? if the answer is yes to all of these questions i'd look elsewhere. my guess is the answer isn't yes, then i'd check it out and take a look at the gears and bearings.
Car: 1986 Camaro SC
actually i had a speed shop do it and when you crawl under the car you can turn the driveshaft a little till it catches the rear
zippinz
Jul 10, 2007 11:14 PM
