Missing Speed
Old Jun 28, 2002 | 10:39 PM
troberts2's Avatar
Missing Speed
The car: 89RS 305 auto, completely stock original, new motor.
The facts:
Speedometer accuracy confirmed by radar
Tachometer accuracy confirmed by engine analyzer
700R4 trans with 0.70 final ratio
Differential with "6HP" code indicating 2.73 ratio
Tire radius = 13 inches
70 mph = 2200 RPM
80 mph = 2500 RPM
90 mph = 2800 RPM
The problem:
Speed should be much higher for the given RPM or RPM should be much lower for the given speed. I am certain the rear end has never been touched, but the calculations indicate an axle ratio of around 3.45, which would be a "6HL" axle. Could my axle be mismarked, or is there possibly some really bad loss somewhere?
Tom
Old Jun 30, 2002 | 10:18 AM
Rustynutz's Avatar
I haven't seen a calculator that goes by a tires radius. It's either diameter or cicumference. Diameter is how tall the tire is and circumference would be a measure of the overall tread of the tire, like wrapping a tape measure around it.
Old Jun 30, 2002 | 10:44 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, jack the rear of the car up (use jackstands please) and on the pass. side rear tire make a chalk mark on the tire and on the floor. Make a chalk mark on the drive shaft. Rotate the pass. side tire foward and count how many times the driveshaft rotates. If the driveshaft rotates around 3 1/2 times to one rev. of the tire you have 3.45 gears ect, ect.
Auggie
Old Jun 30, 2002 | 12:45 PM
troberts2's Avatar
To Rustynutz: the calculator provided by this site uses radius but it's pretty straightforward to convert to any other unit you prefer.
pi x (D or 2r) = c
https://www.thirdgen.org/newdesign/t...ulations.shtml
To Auggie: I checked per your recommendation, first with psngr wheel lifted and then with both wheels lifted, repeated several times each in both directions, and I think there's something wrong with the test. Every full tire rotation yields approximately 1.25 driveshaft rotations. What gears is that?? Any ideas what's going on out there?
Tom
Old Jun 30, 2002 | 10:01 PM
Auggie's Avatar
Well, man I don't know? The only thing that I can think of is that I forgot to tell you to put the tranny in "N". This method has always worked for me???
Auggie
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
