almost lost my 9-bolt today.
Old Jun 30, 2002 | 12:42 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i d@mn near lost my B-W 9-bolt today when it RAN OUT OF FLUID!!! i just replaced the diff cover seal and have not noticed it leaking at all. but today i hit the clutch to start it and as it was rolling backwards i began to hear the gears meshing together, so i looked under the car and much to my dismay the diff was SOAKED!!!!! so tomorrow i get to replace it again. a couple of questions for all you x-perts out there, first one sounds really dumb and really is just a reassurance of correctness to myself, do i use RTV on this seal? if so, do i use the red kind or what kind do i need? i used the red stuff last time. my next question is, ive scanned the forum and i noticed that it is controversial whether or not to use posi additive to this rear end, should i? i did last time and have noticed no problems at all, is there any harm in this?
Old Jun 30, 2002 | 06:55 AM
ausrs's Avatar
if t he faces of the housing and the cover are ok you need to use no silastic !
as for t he additive ,personally i use it in mine BUT GM in aus (the 9 bolt rear is still current in aus )
reccomends that the only time you need to use the additive is if the rear end "chatters"
Old Jun 30, 2002 | 08:25 AM
Lounge Lizard 6's Avatar
I use Redline's light-weight shock-proof (smurf blue in color) in my 9 bolt. I've not had to run any additive.
Linson
Oct 24, 2025 02:00 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
3.8TransAM
Sep 27, 2015 08:37 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
