Which yrs/vehicles
Old Jul 9, 2002 | 12:06 AM
91TA's Avatar
Which yrs/vehicles
I have searched the boards and can't find the answer I need, I know I've seen this question before but cant find it now that I need it. My question is...Which years and vehicles can I find in a junkyard to pull a rearend that came factory with 3:42 gears. I have herd that S-10s came with these gears but just need to verify that. I want to be able to go to a yard and pull the rear, change the fluid and put it on my car. One more thing, anyone got a ball park figure of what I might have to pay for a good rearend. Thanks
Old Jul 9, 2002 | 12:31 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if you want to be 100% plug and play you will have to limit yourself to f-body's due to the torque arm mount, if you get one from an s-10 all you will be able to use is the ring and pinion, and the carrier, and you will have to get them installed on your axle housing
Old Jul 9, 2002 | 12:50 AM
91TA's Avatar
Ok. I will stick to a F-body. What years can I find a 3:42 rear in. I guess it would be less trouble if I just stay with the drum rear, but I might consider a disk setup.
