no o/d or drive. help please
Old Jul 10, 2002 | 07:50 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
i was on the interstate driving home at about 65mph when it happened. out of knowhere my rpm go crazy high so i slap it in neutral and it is ok. i pull over put it in o/d start to go everything is fine shift to second, still ok shift to drive nothing rpm just go up same thing with overdrive. so i limp home in second gear.
i have 1st 2nd and reverse no drive or overdrive.
i have tyhe standard 700r4 auto trans what happened inside it to cause this.
any help greatly appreciated
Old Jul 10, 2002 | 08:56 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
that happened to me once, i never found out whar really happened, some say i burned up the 2-4 band, or the 3-4 clutches, others say it could have been some crud stuck where it shouldn't be. all i know is the fluid was not burnt, and the pan was clean when we pulled it to see if any pieces were in there.
sorry i of no help but i am curious what the rest of the board thinks
Old Jul 10, 2002 | 12:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
SAME EXACT thing thats wrong with my 91 700r4, good r,1,2, drive is out, and 4th I have to rev engine (v6) to 4200-4500 rpm for it too kick in. I tryed adjusting the tv cable, new filter, new fluid, no go. I fixing to send it to shop and pay 700 bux to have it rebuilt Thought I would let you know I its not just your car, I think its a 700r4 "thing" BTW 165,000 miles on it.
Old Jul 10, 2002 | 01:33 PM
Bad Analogy's Avatar
The same thing has happened to my 700R4 89 Formula. I have 1st, and 2nd just fine, but i have to rev the engine to over 4000rpm to get it to shift to drive. I have no OD at all.
I'm hoping there is something i can do short of rebuilding it, though. If there is nothing i can do, i may opt for a TH350, as i wont be driving it everyday for much longer and the TH350 is cheaper.
Old Jul 10, 2002 | 03:59 PM
Pro Built Automatics's Avatar
The 3-4 clutches are the weak point in this transmission (as you have noticed). This is the most common failure on this unit. When you lose the 2-4 band, you have 1st & 3rd, when you lose the 3-4 clutches, you lose 1st & 2nd. It is rare that a valve in the valve body, or the governor is stuck, etc., that will cause these things to happen. On my units the 3-4 clutch failure rate is zero, (no comebacks with 3-4 clutch failure in over 5 years) We use the Borg Warner Hi-Energy clutches, (7 clutches for road racing and 8 for drag racing or Heavy Duty), the Corvette servo, .500 main boost valve, special pressure regulator valve, Kolene steels when necessary, the Trans-Go Performance Shift kit or HD Shift kit, Trans-Go HD forward & direct return springs, and the 3-4 clutch clearance at .040 - .055. I have found no better setup. This is only a part of what needs to be done to make this unit last, but as you see it is a big part. If I can be of help let me know?
Old Jul 10, 2002 | 05:14 PM
1st and 2nd gears are fine. Only shifts into drive when rev'd over 4000rpm and then NO overdrive.
Old Jul 11, 2002 | 01:05 PM
Dale's Avatar
Engine: 350 S-TPI
so pro built, where you live, how much for a new one, what kind of warranty?? Or is this something I can do with a little bit of time??
Old Jul 11, 2002 | 02:50 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
forget about it i bought a probuilt
Old Jul 11, 2002 | 02:54 PM
I'm in southern California, trans comes with a one year warranty, price on the Street/Strip or Road Race 700R4 is $1395.00 outright (good for over 500+ horsepower). The HD 700R4 sells for $1275.00 outright.
Old Jul 11, 2002 | 03:27 PM
Dale's Avatar
Engine: 350 S-TPI
well, I dont think my v6 will put out 500 ponies, and shipping on that thing to Arkansas would be WHOA so as nice and strong as it sounds, I gonna have to pass
Fireslash
Apr 11, 2016 06:43 PM
Whata69
Mar 2, 2016 06:34 AM
bjpotter
Oct 4, 2015 07:48 PM
64Chief
Sep 12, 2015 08:05 AM
Fronzizzle
Sep 8, 2015 12:10 PM
