Transmission ?
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
Transmission ?
I recently purchased a 700R4 for my 85 Z28 since mine had developed the infamous 3-4 clutch failure. The trans that I got came out of an '86 Astro van. My question is if anybody knows if the valve bodies and govs are the same on both of them or if i need to change them. Since I've installed the trans, the shift from 1-2 occurs at 3500 RPM, 2-3 at 3200 RPM, and doesn't go into 4th (OD). Shifts are the same at part throttle and full throttle. I've adjusted the TV cable many times using all kinds of instructions. Any help would be appreciated.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
