Why does my 700R4 do this???
Subscribe
Jul 20, 2002 | 10:06 AM
When I have my shifter down in 1st gear, the transmission shouldn't shift until I manually shift the lever into 2nd gear. However, when I have it down in 1st gear and I hit 5500rpms at WOT, the transmission shifts into 2nd gear on it's own. I could understand this automatic shifting if I had it in drive but not when it's down in 1st gear. I've heard the 4L60E does that but I didn't think the 700R4 did. Does anyone else have a 700R4 that does this and is it normal for a 700R4 to do that?
Another question, if it shifts itself at 5500rpm then I obviously can't rev it any higher like I want to so how do I fix it??
Reply 0
Jul 20, 2002 | 12:08 PM
Its normal for it to shift like that. Its called a governor upshift, the governor is forcing the shift. You can probably change the springs in the governor or replace the governor itself with a different one. Anybody else know how?
Reply 0
Jul 20, 2002 | 02:46 PM
If you want to stop this from happening remove the MTV upshift valve, toss the spring and reinstall without a spring. This will allow you to hold your transmission in any gear at any rpm. The MTV valve is the second bore small bore on the passenger side front with a visible roll pin and you can remove it without removing the valve body.
Reply 0
Jul 20, 2002 | 11:57 PM
Very interesting guys. Thanks for the info. I've never done anything to the tranny other than installing it, removing it, and changing the fluid/filter so I'm not sure I want to tackle this one or not but who knows, maybe someday I'll just get out there and do it.
Reply 0
Subscribe
