Loud bang when flooring it?
Old Jul 28, 2002 | 07:49 PM
Rallyssport's Avatar
I own a 92 RS 305 TBI and everytime i floor it there is this loud bang, sometimes it sounds like its coming from the back then other times its coming right under the shifter. Im thinking a tranny mount is broke but why would it make a bang in the back?? Thanks
Old Jul 28, 2002 | 08:16 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Sounds like a busted tranny mount.
Old Jul 28, 2002 | 08:24 PM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
definitely a busted tranny mount, fix immediately! i went through the same thing and it bent my driveshaft and fragged all the internals of my rear end from my neglect. it's an easy task to fix and way worth it. a lot easier to change mount than whole rear end! good luck.
Darth_TransAm's Avatar
I had the same problem in my 84 TA. I would hear a loud bang on take off and also at 1-2 shift (5-speed) The problem was not my tranny mount, but the support brace (?) that goes from the tranny to the rearend. The bolts had sheared off and the brace would bang against the tranny. Crawl underneath and bench press the brace, it should not move.
Old Jul 28, 2002 | 08:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
definitly a tranny mount. it may sound like its coming from the back but its not. get an energy suspension mount and you wont have to worry about changing it for another 20000 years
Old Jul 29, 2002 | 09:54 AM
MdFormula350's Avatar
on my 1988 firebird 350, auto; i had that same bang when i would shift, you could see the whole console shake so i fixed that buy changing the tranny mount. After that the tranny did not shake anymore, but the i also had the same noise/feeling you do coming from the rear end area. I think what i had was called "wheel hop" when really getting on the gas this would happen, and i fixed that buy getting the lakewood rear lower control arms for like 80 bucks and that fixed that.
So i had two problems that would make the car shake and hop when getting on the gas, i thought the car was actually falling aparts, but actually only 100 dollars and 1 hour later it was all fixed.
Old Jul 30, 2002 | 08:13 PM
ok..i finially got my car up on a lift and found out that it is a tranny mount. I also checked around to make sure nuttin else was loose and everything looked fine...thanks everyone.
LC2 TECH
Oct 13, 2015 11:53 PM
loud91rs
Oct 5, 2015 10:05 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
