manual to automatic
Old Jul 31, 2002 | 05:04 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
manual to automatic
Hey all i recently bought a 85 z28 with a 350 ci motor and it's a 5 speed. i am going to be rebuilding a 350 i have laying around. my goal is about 500 horses and i want to put in a th400 trans with all the goodies (maual valve body, reverse pattern, maybe a trans brake.) what is involed in swapping from manual to automatic?
thanks
Old Aug 1, 2002 | 04:29 AM
DLTrahan83's Avatar
Hey if anyone knows i wanna know too. I am having the same problem too. ihave a 83 firebird for my g/f and it has a 4-speed manual and i wanna convertit to a automatic so she can drive it. I tried to convice and tech her but no way no how. She just wants to put the carin gear and drive.
Old Aug 1, 2002 | 03:41 PM
black83z's Avatar
I dont know a whole lot about this, and am planning the opposite of this swap. I think you'll need an automatic pedal cluster - the whole thing, not just pedals, a new driveshaft..or cut your current one, and possibly new tranny mounts or crossmember. Why not just go for the 700R4 instead if youre gonna build it up like that? That way you have overdrive for those high speed highway cruises. Then you can sell me your manual tranny, since you wont need it anymore.
Matt
Old Aug 2, 2002 | 07:40 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Sphoon makes a crossmember, as for the shifter... It would probably be easier and sweeeeeter to just buy a universal aftermarket ratcheting type deal and fit it into the console somehow. Weld/pop-rivet some steel over your tunnel hole. For the TH400 you need to find some way to mount an electric kickdown switch either on the peddles or on the throttle body. Probably need to change driveshaft length, but I believe the splines count is the same. The TC will bolt up no prob.
Falcon50
Aug 22, 2020 03:26 PM
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
