Rear End And T-56 Question
Old Aug 4, 2002 | 11:22 PM
PIMPINPHIL's Avatar
hi,
im buying a 93 t-56,now i know they have a different 6th gear,however,i under the impretion that it will work good with my setup,as does the 94-97 t-56 with the 4.11's,i have factory 373's,limited slip,so will this be a good combo?or am i going the wrong way?also,would you guys make my limited slip,into full posi if it was your car?and if yes,which kit would you buy?thanks.
Old Aug 5, 2002 | 05:49 AM
ede's Avatar
ede
the trans will work fine with 3:73s. do you mean run a spool, don't. are yuo getting posi and limited slip confused? the only differance is the spelling, same thing.
Old Aug 5, 2002 | 09:54 AM
PIMPINPHIL's Avatar
hi,
i thought posi,was a full blown out posi,where both tires spoon egually all the time,and limited slip,only spun when needed,like it wouldnt going around turns at higher speed.???
Old Aug 6, 2002 | 04:59 PM
Gta-Paladin's Avatar
i thought a spool was full blown posi and a locker isnt a spool but its pretty damn close when its locked up.... and then my borg warner .... well, that works when it wants to
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
