t-56 flywheel 85 and earlier
Old Aug 16, 2002 | 03:03 PM
PIMPINPHIL's Avatar
hi,
where did you guys get your flywheels for your 85 and earlier blocks? summit wants 338 dollars for theres,trying to get a little cheaper,thanks.
Old Aug 16, 2002 | 10:51 PM
ScreaminDeamin85Z's Avatar
sorry to say it but, that actually sounds about right. the cheapest i could find for was 386. Look the manu website and find the local dealers and try them.
Old Aug 18, 2002 | 12:07 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Hey PIMPINPHIL,
Are you talking about a stock replacement, or are you doing a 6-speed conversion? If you need a flywheel for a 6-speed it is possible to use a stock LT-1 flywheel if you have it re-drilled for the 2-piece rear main seal crank's bolt pattern and have it neutral balanced by a competent machine shop. When I got my 6-speed it came with a flywheel which the guy I got it from told me had been re-drilled and neutral balanced. The holes looked a little weird, but I installed it and it works perfect! and it's gonna be a lot cheaper than a new flywheel. If you're looking for a stock replacement for a t-5 I dunno for sure about that, although I do have an extra one . One benefit though with the t-56 flywheel is that it's the same diameter as the t-5 flywheel but accepts an 11 inch clutch I believe, however that there is a difference in the thickness of the flywheel so I don't know if it'd work with a stock 5 speed. Well, good luck!
-Paul
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tonys91rs
Oct 10, 2015 03:31 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
