T-5 To 700R4
Old Aug 18, 2002 | 02:00 AM
TPIGUY's Avatar
T-5 To 700R4
Hi all,
I am going to switch out my T-5 for a 700r4 when it breaks.
I wanted to know what I have to do what ill need. Is It going to be hard?
Thanks in advance
TPIGUY
Old Aug 18, 2002 | 02:36 AM
Don_89Iroc's Avatar
i would stay with a 5-speed!!!
Old Aug 18, 2002 | 11:15 AM
TBI305Camaro's Avatar
Yes why would you want a 700r4?!? I know the T-5 kinda sucks but so does the 700r4. Ill tell ya what Ill trade you trannys because I was wanting to switch to a manual
Old Aug 18, 2002 | 12:12 PM
TPIGUY's Avatar
Well,
I don't like the t-5 because it's so weak, plus it's just a pain in the a$$ when in city traffic.
TPIGUY
Old Aug 19, 2002 | 01:48 PM
solstone's Avatar
Car: Black 91Z
Transmission: 700R4 (from factory T5)
Hey TPIGUY, I've got a '91Z that was swapped to an auto and I can tell you it's been nothing but problems. The biggest being wiring the transmission, the wiring harnesses on auto/manual trans cars are different and if you don't swap it out you'll need a trans shop to wire it, and for them to do it properly will cost some $$$. Then you'll need a custom burnt prom chip to lower your idle speed, and an auto speedo sending unit and speedo gears, assuming the trans you're getting doesn't have the right ones. I'm gonna convert it all back to manual as soon as i get the dough.
I know city driving sucks cause I live in LA, but believe me it's not worth it!!
Old Aug 19, 2002 | 05:57 PM
Odyssey's Avatar
Switching to a 700R4 is worth it to him if that's what he wants to do. I took out my T5 because I started hating it in traffic. Plus I could never get a decent launch with it while racing on the street. Now I got a built 700R4 and couldnt be happier! To switch you'll need.... VSS for 700R4, shifter and shifter cable, tranny fluid lines that go to the radiator, torque converter bolts, flexplate, shorter flexplate bolts, 700R4 style torque arm bracket and that's about it.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
