What driveshaft for short shaft 350 trans?
A friend of mine needs this info. I told him try and get a 82-84? ds from a camaro/firebird with the auto (200c).
are there any other options, Cheap.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's your only option. It's hard to lengthen the shorter driveshaft. It's easier to just use a long tail shaft TH350.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
a thirdgen thm200c driveshaft, alot of 82's had these trannies, if the pan looks just like a th350 but only with 11 bolts around it instead of 13 then thats what shaft you need for 6" tail th350 swap.
im stil trying to find out if the B&M bracvkets kit will work for a 9" tail th350 cuz thats all i have right now, i cant find any good 6" tail th350's around here right now.
no one seems to know answer to this right now for some wierd reason..
good luck
good luck
theshackle
Mar 5, 2017 06:37 PM
