From park to drive=hard yank
Old Oct 14, 2002 | 09:15 AM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
OK i have a 91 rs 700r4 when i shift from park to drive it yanks hard like shake your head hard and people are like who man thats bad so whats up
Old Oct 14, 2002 | 09:23 AM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
if your idle is to high, or your foot is on the gas that will happen
your u joints could be shot, you can check the slope by holding the break and shifting from drive to reverse while some one watches the ujoint to see if it moves
The rear end could be shot too, not sure how to check that though.
Old Oct 14, 2002 | 12:51 PM
jonarotz's Avatar
Car: 91 Z28
I will sometimes get the same problem. I have a 91 Z28 and after the car sits for awhile I will back it out of the driveway and put it in drive, it will take a second to engage and them it hits drive real hard. It will shift hard going into 2nd too. It will only do it once and only if the car has been sitting for a couple days. I know that I have a sticky valve because sometimes when I am at cruising speed I can throw it in neutral, hit the gas and the car will want to pull slightly until the vave fees up. (Only a split second though, Not for long).
Old Oct 15, 2002 | 12:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
idle too high, with auto trans you want around 550-600 rpm,
Old Oct 15, 2002 | 01:56 PM
chevy350's Avatar
From: working at a horse farm, gonna go to somerset county tech. inst. in january.
Car: 87 GMC sierra classic
Engine: fresh 350, minor mods (its been de-emissioned too)
Transmission: professionally re-built 700R4, REALLY hard shifts & bigger clutch packs
My truck does the same thing. Its not the trans, cuz i got mine rebuilt and didnt do anything for it. It idles pretty high, around 700 when warm. Im pretty sure ive narrowed it down to the IAC.
Old Oct 15, 2002 | 06:20 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Check your torque arm mount, it may be worn and your torque arm could be slappin around. Also, check your rear brake cylinders. If one is leaking, it will cause your wheels to move and jump forward. That's what mine was doing.
Ed
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
