How long will my rear end survive with this motor?
Old Oct 15, 2002 | 04:28 PM
Berlinetta's Avatar
Im building a 383 for my 91 RS and i plan on using an aftermarket 6-speed and 3.73 rear gears. Motor will be around 350hp (flywheel) by the time it goes into the car. How long will that factory 10 bolt survive? Im guessing not very long.
Old Oct 15, 2002 | 06:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They seem to last just fine in the LS1 cars, same rear and all, with more power than that... so yours should be OK if not abused (high-RPM clutch dumps on slicks, speed shifting, etc.)
Old Oct 15, 2002 | 06:51 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Seen a fellow at the track Sunday running 730s, with a 406. Stock 10 bolt, with gm 373s. NO girdle either. Says he's been running it for two years, 11" slicks. Hasn't blew it yet.
Old Oct 15, 2002 | 06:59 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
My 10 bolt has stood up with my 406 so far (touch wood) Next spring when I get it to the track for some hard runs we will see what happens.
Old Oct 15, 2002 | 07:08 PM
Berlinetta's Avatar
that'll kick *** if it can hold out for a little bit. I dont feel like dishing out 2000 bucks for a bad *** 12 bolt. Ill have to try and keep my foot out of it. That'll be a little hard to do though
Old Oct 15, 2002 | 07:23 PM
4L60bliss's Avatar
Usually easing into the throttle will help prolong the life. Slicks and nuetral drops (or anything that will "shock" the drivetrain) could be catastrophic. I'm not really qualified to answer, since I can build them, but have not pushed them to the limits, but I have seen people run 11's on there 10-bolt.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
