what could the problem be? something in the valve body? trans fluid level and color is good and tv cable is setup correct. what do u guy think
Brian
Brian
What happened before it started doing this? Did you rebuild it? Did you install something, or did it start doing this on its own? Will it shift out of 2nd and into third?
