Differnces in 3550s and TKOs
Old Oct 28, 2002 | 07:21 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
let me see if I got this straight
All 3550s have 10spline inputs (unless otherwise modified by forte or someone) and C4 output yokes.
All TKOs have 26spline inputs and C6 (31spile) outputs
The mod II of each trans is the only way to get the improved strength third and .82 overdrive
For a 3550 to fit a GM- fbody, it needs to have a different bellhousing, speedo conversion, and shifter location. (and the torque arm mount)..
What else is there I forgot..
Anybody know if a mod 2 (II) third gear can be fitted to a non-mod 2 case? I guess it can unless you are talking 3550 to tko switch...
I hear a 2.95 first gear will be available in june-july..
Old Oct 28, 2002 | 02:49 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Try this site. It may help
http://www.ttcautomotive.com/products/tremec.asp
deracer
Apr 11, 2016 12:04 AM
jharrison5
Aug 19, 2015 05:53 PM
JoeCool
Sep 27, 2001 08:13 PM
JDMZ28
Sep 12, 2000 02:29 PM
