allen head size
Old Nov 14, 2002 | 01:49 AM
mrbboy's Avatar
allen head size
Does anyone know what size allen head I need to use to remove the fluid fill bolt on the differential?
Rene
Old Nov 14, 2002 | 01:52 AM
kingrobert's Avatar
are you sure it's an allen wrench, all the ones I've done I just used a 3/8 ratchet with an extention on it
Old Nov 14, 2002 | 02:18 AM
mrbboy's Avatar
I was going to replace the fluid but I didn't have the right allen wrench for it. I am sure the bolt is an allen head bolt. The size is smaller than 10mm but bigger than 8mm. I think it may be a standard size allen head. Did you mean that the fill bolt on your differential just takes a regular 3/8" socket? A socket will not work on mine.
Rene
91 RS 305
Old Nov 14, 2002 | 02:21 AM
kingrobert's Avatar
I haven't seen the one on my car, but the one on my truck is just the regular 3/8 ratchet, not a socket, the actual ratchet fit on it w/o a socket
Old Nov 14, 2002 | 06:05 AM
ede's Avatar
ede
sounds like someone replaced it with a recessed hex pipe plug instead of the recessed square, i know i always do when i rebuild a rear. try a 3/8 allen socket
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
