Alright 9bolt guys...
Old Nov 14, 2002 | 06:14 PM
1982chevycamaroz28's Avatar
okay i have a ton of question so be paintent, thanx.
well i just bought a 9bolt posi rear with disk brakes. the guy said it had alittle over 100,XXX miles on it when he took it out of his 87 TA. the thing is that the tag on it says it has 2.77 gears. what kinda gears can i get put into the rear thats better for the 1/4 and street? also i found out that the 10 bolt i have now in the car the one owner that knows a crap load about the car then anyone told my brother he put a posi in there and mine is probably worn out. and i was wounderin is there any way i could use the disk brakes off of the 9 bolt and use it on my 10bolt?( the 10 bolt has drums) Also what kinda axels came in the 9 bolt? did they have 26 or 28 spline axels?
also did i make a bad choice in buyin this rear end? becuz im not sure if the 10 bolt i have has different gears in it or not. if i jack the car up and spin the driveshaft which wheel do i look at to mark to find out what gears i have in the 10 bolt? becuz i dont want to go from if theres like say 3.45 gears in the 10 bolt and go to 2.77's. would goin from if there is 3.45 gears to 2.77's would that hurt my proformance any?
i know ill have more questions about this but these are all the ones off the top of my head right now becuz i think i made a bad mistake on buyin this rear end.
Old Nov 15, 2002 | 09:25 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt is an very strong rear end (much more than the 10 bolt), but parts are more expensive. All the info you need is at www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
Old Nov 15, 2002 | 08:54 PM
hey i emailed u guys about gears and whatnot. maybe ya might wanna check it out err something.
Old Nov 16, 2002 | 02:10 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Sorry, but I have not seen an email from you I try and check everyday and there is nothing. Please try again at miles@koolmeister.com or post here
Miles
Old Nov 16, 2002 | 08:29 PM
the email should be under the sn i5sk8er its my aol account name
88rscamar0
Sep 23, 2015 09:08 PM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
Street Lethal
Sep 7, 2015 01:09 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
Street Lethal
Aug 14, 2015 08:25 PM
