Quick Rear End Question
Old Nov 17, 2002 | 03:29 AM
Fivespeed85's Avatar
Car: 85 Trans Am TPI
Engine: Big Enough
Is there any way i can tell what my rear end gear ratio is without removing the cover and counting?
Old Nov 17, 2002 | 05:11 AM
ede's Avatar
ede
rear the code on the axle tube and look it up i na manaul, works great if no ones changed the gear set. spin the drive shaft and count how many times it takes to make the wheel rotate. lot easier and more accurate to pull the cover, count teeth or read the ratio stamped on the gear, change the oil, nad do a general inspection while you're in it.
Old Nov 17, 2002 | 02:04 PM
MdFormula350's Avatar
you can find out what the car came with by using your rpo codes..
the code are usually under the console lid or in the trunk compartment lid
and then plug them into the decoder..
https://www.thirdgen.org/cgi-bin/rpo/index
Old Nov 18, 2002 | 11:40 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
Re: Quick Rear End Question
You can also use the VIN Decoder on this web site, if you are reasonably sure that it is the original rear end.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
