rear swap.. need some ideas...
Old Nov 17, 2002 | 06:03 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
k i got a rebuilt posi wit 373's for my car.. the problem is someone cut it out with a torch and they messed up the holes where the shocks bolt in.. what would be easier.. takin a sawsall to em and trying to weld the old ones from my old rear on or trying to swap internals? my other rear is the origional v6 open 271 rear.. would it be possible to just swap the internals and use the casing from that? which would be easier/faster.. suggestions please
Old Nov 17, 2002 | 06:24 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: rear swap.. need some ideas...
if you swap the internals, your gonna have to setup the gears again in the other rear end, which is not a good idea if you dont have the tools and know what your doing. I would just weld on new shock mounts, or make the hole even bigger, and weld heavy gauge washers on either side of the hole that match the bolt size.
Old Nov 17, 2002 | 09:15 PM
89RsPower!'s Avatar
yeah problem is i havta swap the brakes too.. dont u havta take the rear apart ne way to do that? cause if ya do i figured it would make more sense to use the good housing from the old open rear and just swap internals.. if im wrong plz correct me.. also will the posi parts fit in the housing?
Old Nov 17, 2002 | 11:23 PM
Car: '91 Camaro RS
well if one rear end has drum brakes and one has disc brakes i can understand the desire to swap them.....if they are the same i wouldnt even bother really. you dont have to take to whole rear end apart to remove the brakes though, the backing plates and stuff just unbolt from the housing ends. All the internals should swap over without a problem as long as both housings are the same
Old Nov 18, 2002 | 10:20 AM
89RsPower!'s Avatar
yeah swapin over my discs.. you havta unbolt the dif cover loosen the pinion and pull the c-clips to release the axles in order to remove the brake assemblys though, correct?
Old Nov 18, 2002 | 10:27 AM
Car: '91 Camaro RS
no i dont think you have to touch the diff to remove the brake hardware, in fact im almost positive.
However, if you plan to do alot of drag racing with slicks, your gonna want a good sidewall so you would use 15" rims.....15's wont clear that disc setup, so if you plan on doing that you either need an aftermarket setup that will clear,or stick with drums
Old Nov 18, 2002 | 04:20 PM
89RsPower!'s Avatar
how would you slip the backing plates past the axle.. its damn near impossible unless you cut the backing plate with a sawsall unless you pull the axle..
Old Nov 18, 2002 | 04:29 PM
Car: '91 Camaro RS
hmmm.... see im at school right now so i cant just go out to the garage and look at it, im trying to remember....the rear is in my brothers car, so ill find out
Old Nov 18, 2002 | 09:16 PM
Momar's Avatar
I forsee the axles being pulled if you want to swap brakes from one rear to the other. I had to on a 9 bolt anyway, but at least they dont use c clips so you can just unbolt the axles.
Ben
Old Nov 18, 2002 | 09:29 PM
Car: '91 Camaro RS
ahhh yes....that was what i was trying to remember.....i was thinking c-clips if you had to pull out the axles. thats not big deal then.....
all you need to do is take the retaining bolts out of the housing end, and slide the axle out....no need to remove the diff cover, cause like momar said the 9-bolt has bolt in axles not c-clips
Old Nov 18, 2002 | 09:34 PM
Momar's Avatar
Actually I think that he has a 10 bolt right? If so he will have to pull the cover off and pull out the c clips but that shouldnt be to bad. If it is a 9 bolt it is 4 bolts and it slides out.
Ben
Old Nov 18, 2002 | 09:43 PM
Car: '91 Camaro RS
yup
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
