Trans Am rear end to Camaro rear end?
Car: 91 RS Camaro
Engine: 305 TBI
Does anyone know if an 84 Trans am rear end will swap out directly with my 90 RS camaro rear end?
Car: 4
Engine: 6
Transmission: 5
Yes. At least, if the 84 has drums.
However, if the 84 rear has disc brakes, they suck, and you'll need a different master cyl and proportioning valve to get them to work right, after you fix all the problems that those have.
Car: 91 RS Camaro
Engine: 305 TBI
That is dishartening. The rear end I am looking at does have disc brakes. Is that gonna be a big hassle? Do you have any idea what master cylinder and proportioning valve I will need? Can you elaborate more on that I was waiting on a response back from the seller and then I was going to the bank for the money until I heard what you said. Now I am not so sure I want the rear end. Please help.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
is it a 9-bolt? my 9-bolt came from a trans-am with disc brakes. I had to fool around with it a bit to get it to work, but i didnt change any hardware at all. maybe they arnt working and i dont even know it? I havnt had to change any brakes at all in the year ive had it though... no telling. hmm. now IM wondering?
Car: 91 RS Camaro
Engine: 305 TBI
I don't know the seller hasn't sent any pics he just said it came out of a 84 Trans am and it is posi with disc brakes.
well i got a 9 bolt posi disk rear for a guy i know and all u need is well the rear end and the prop. vavle and thats it, its a basic swap. but with my swap im also addin line lock so i wont kill the brakes but ill kill everything else, lol. but u will need also the parking brake cables too.
Be aware however that the disc brakes pre-87 or so really sucked!! They had a whole different type of caliper system and the piston had problems with it from day 1. The PBR system is far superior.
Contact :hail: AndyZ28 on this board and talk to him about this, he has a whole upgrade kit that is WELL worth the $$ you spend on it!!
Even if you can't/don't wanna spend more money on it, he is a wealth of information about the braking systems (among other things too!)
Hope this helps!
Hope this helps!
Car: 91 RS Camaro
Engine: 305 TBI
So if I got rid of the caliper all together and went with an aftermarket caliper things should be better then huh?
why dont u just make sure the non PBR calipers work first before ditching them. becuz if they work fine then why get rid of something that works. on the rer i got i got it for 200 bucks and that was everything including the prop. vavle and the rear , the guy put new rotors and calipers on it before he sold me it.
and plus ive heard with the PBR calipers u need bigger then a 15 in rim, is this true or no?
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
