700r4 4-3 Downshift Switch
Old Nov 25, 2002 | 05:33 PM
Acidtalons's Avatar
Just installed a B&M shift kit in my 700r4 (1986, no auxilary valve body). There are two wires that connect to the 4-3 Downshift pressure switch. There is one wire from the Solenoid assembly that is red and one from the wiring terminal in the transmission case, this wire is also red. which wire goes to which terminal?
I am looking in my ATSG Service manual but it does indicate which wire goes on which terminal.
The pressure switch labeled A in the picture is the one I am refering to.
Old Nov 25, 2002 | 06:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm pretty sure it doesn't matter.
Old Nov 26, 2002 | 08:58 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Sometimes U can figure something like that out by laying the wires in the some what same original position & observing the natural way the wires are laying & toward what switch they reach the easiest.
njdaewo
Old Nov 26, 2002 | 10:07 PM
Crosley4's Avatar
As I read your post it sounds like you are concerned if the red terminals attach to different tabs on the pressure switch.
Both wires connect to the same switch. it does not matter which red wire to which terminal since the switch connects the two together electrically when the switch is pressurized.
FWIW..... I am glad that my photo possibly helped you.
At least the jpg has the same name.
Old Nov 26, 2002 | 11:17 PM
Acidtalons's Avatar
Thanks Crosley. The help is much appreciated, Finally I can put my tranny back together with a clear conscious that it won't break, atleast from the switch anyway.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
