T56 clutch and flywheel question
Old Nov 26, 2002 | 10:01 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'm looking at getting a T56 change over package that includes the clutch and flywheel but I can't reuse the flywheel cause I have a 2 peice rear main. My question is, if I get a flywheel for a 2 peice rear main, will the stock T56 clutch work with it or does the clutch have to be for a 2 peice setup. I'm not too familiar with these setups so I don't know the answer to this simple question but I'm sure someone here does, thanks for any help.
Tom
Old Nov 26, 2002 | 10:42 AM
Arntzman's Avatar
You neeed to get a Centerforce flywheel, PN 700107. Its a flywheel for a two piece rear main seal, but uses the stock LT1/t56 pull style clutch. A regular flywheel will not work with the LT1 style clutch, thats why you need this special flywheel. I think I got mine from Summit or Jegs for around $300, but that was 2 years ago.
-Good luck
-Dave
Old Nov 27, 2002 | 11:32 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
McLeod also makes this special flywheel for two piece rear main seal cars that want to use the T56.
Old Nov 28, 2002 | 06:35 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Lately I've been considering just getting a trans and bellhousing and just buying the clutch and flywheel seperate. So if I bought a clutch for it, would I still have to get an LT1 clutch or would I be able to use a regular type clutch with a regular 2 peice rear main flywheel for a T56? Thanks agian.
Tom
Old Nov 28, 2002 | 10:08 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ya gotta use the the LT1 clutch. The bellhousing is setup that way. Get a tranny and bellhousing then get a aftmkt flywheel and aftmkt Lt1 Clutch. GOod luck.
Rick
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
