Moaning rear end...
Old Dec 4, 2002 | 11:01 PM
kingmatt16's Avatar
Moaning rear end...
The rear end on my 89 Iroc 5-speed whines only when engaging and disengaging the clutch, and also when I take my foot off the gas it starts to moan. If I am accelerating or giving it constant gas (such as highway crusing) the rear end is quiet, however as soon as i let off the gas it feels like something is loose or out of spec in the back. Any ideas?
Thanks alot!
Matt
Old Dec 5, 2002 | 01:00 AM
MdFormula350's Avatar
do you have the right fluids in the rear...
also maybe the pinion nut is loose for some reason. my moms van whines in the rear after replacing the bearing/seal. i guess i didnt tighten that nut down enough.
just a guess though.
Old Dec 6, 2002 | 10:54 AM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
I have a 91 RS and mine does the same exact thing, I was fixing to change the rear end gear oil but what is the best to use??
Old Dec 6, 2002 | 07:49 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
My 5-speed does the same thing. I changed the rear end oil with Valvoline Synthetic 80w90. It really didn't help much. I check my axle seals and no leaks and the pinion nut wasn't loose either. My automatic has about the same mileage on it and doesn't have that problem. I'm beginning to think that the T-5 may add stresses to those rear ends. I've settled a rebuild and a gear upgrade when the modding begins. Good luck.
Old Dec 7, 2002 | 12:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
Your sure its not your clutch right? Check those U joints also. GM sells the proper fluid with additive for those that dont know which fluid to use.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
