700r4, no up shift
Old Dec 6, 2002 | 11:04 AM
re8s10's Avatar
700r4, no up shift
I have a 91 S10 with an L98 and 700r4 from a 92 IROC . The other day I installed a B&M Pro Stick shifter .When I went to try it out, the trans. stayed in 1st. gear, it would not up shift. I have park, reverse, and neutral but no up shift from first. When installing the shifter I had to manually shift the lever on the side of the trans. quite a few times ,while adjusting the cable.Is it possible that I got something stuck or disconected while manually moving the lever? The only thing that has changed is the shifter . Thanks for any help .
Ron
loud91rs
Oct 5, 2015 10:05 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
