runnign th350 minus the kickdown cable ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
anyone know of anything bad that could happen by running stock th350 without cable connected ??
thanks for anything
thanks for anything
Car: 82 camaro SC
You won't have the kick-down via the throttle. Driving along around 40 mph, then floor it to pass someone--no kickdown, the tranny will stay in 3rd until you manually pull it down. Why, because the tranny doesn't 'know' you just floored it--as far as it can tell you are just idling along. Probably not a good idea, it can slip the torque converter enough to overheat the tranny if you don't downshift when needed.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I run without one. Th350 with 2400 B&M converter. Its only temporary for me though, I have maybe 2000 miles on it. WOrks great. like what was said, you will have to manually downshift. no biggy.
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
