Which T-5 VSS works w/ T-56?
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Nobody on the trans board will help, can you guys????
I just called a dealership and they said that there are two different part numbers for the speed sensor for a 90 Bird with a T-5.
1 Part# 1045 6088 $79
2 Part# 1045 6089 $39
I'm going tomorrow to look at both to see what the difference is. Maybe it has something to do with gear ratio's.
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Originally posted by JR305
If you are swapping to a T56 neither will work. You need a conversion box. I used the dakota digital SGI 5 box, just run a search for the box and you will get all the info you need.
What he said.. The reason why is the VSS is 2 different sizes and the one for the T56 gives off more pulses than a T5 one.
There are ways out there to convert the T56 tail shaft housing to accept the T5 VSS but it isnt worth the $$ or the troubble.
Kat
Car: 83 Z28
Engine: 406
I'll have to search the archives again, but I saw that people just used one from a t-5 that works. I'm buying them both tonight and see what I can do.
Hello, Michael
Aug 20, 2015 03:19 PM
Mubie
Sep 30, 2001 04:56 AM
Josh 91RS
Mar 12, 2001 04:34 PM
