how hard to change syncros?
Old Dec 21, 2002 | 04:34 PM
farm-kid/88camaro's Avatar
A buddy of mines having some trouble with his 5 speed which is in an s-10 with a 2.2.
Hes been told the syncros are shot and wouldnt mind attempting it himself.
How deep in do you have to get for them? Is this a little bit too much to take on?
Thanks, Jon
Old Dec 21, 2002 | 05:14 PM
justinhebert's Avatar
You basically have to rip the tranny apart. The syncros are between every gear so its basically as involved as rebuilding the whole tranny. I wouldn't recomend this for a beginner but if your up to the challenge.....:lala:
Old Dec 22, 2002 | 05:23 AM
ede's Avatar
ede
never did a t5, worked on a lot of t10s and muncies. not really hard to do, just press the gears off and swap the syncros. you'll need a press and bearing seperator.
Old Dec 27, 2002 | 11:09 PM
bubafett's Avatar
Get a Junk yard trans for the s10 you will be happier.
I rebuild my Camaro t5 and broke a gear while pressing it off. The gear alone was $105. All parts total about $300.
I bet you could get one from the J yard cheaper for the s10.
Old Dec 28, 2002 | 08:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The synchros hardly ever go bad or wear out. I doubt he needs to tear into the trans.
If his trans is hard to get into all gears without crashing, then it needs a clutch. Maybe just the pilot busihng / bearing; but if I was going to tear one down all the way to do that, I'd go ahead and put in a new clutch, it can't be long for the world either, if the pilot has enough use to be worn out.
Old Dec 28, 2002 | 04:51 PM
thanks for the reply's guys
Its starting to sounds like it is the clutch, at least with the problems hes having thats probably what it is.
I think he just asked someone he knew and they shouted out bad synchros without really examining the problem further.
maroe624
Apr 16, 2017 08:29 AM
gixxer92
Sep 1, 2015 04:32 PM
FreeSpirit
Aug 29, 2015 05:47 PM
johanlindgren
Aug 16, 2015 12:16 AM
