What stall?
Old Jan 5, 2003 | 10:35 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
What stall?
What would be a good stall for my car, its a 350 prob about 9.5 or 10 to 1 compression, 600 or 750 cfm carb, xe262 cam .462/.469 lift 1300-5600 rpm, with headers and flows, 700r4, with 3.42 open rear.
What is the stock stall on a '92 RS, also what about the 95 and up S-10 stall or Corvette, would either of these be a good stall, or could i use mine.
Thanks,
Kevin
Old Jan 5, 2003 | 11:46 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
should be OK with yours. the XE262 is popular, will work will stock stall, and makes decent power all around. it will like your gears, too.
Old Jan 6, 2003 | 12:45 AM
Engine: 383, L69
ok thanks, thats what i wanted to hear, it sucks being on a limited budget
Old Jan 6, 2003 | 12:56 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
heh, im swapping out my 234/244 cam for the XE262 cam so i can use my stock stall 700R4 because i cant afford the nice 9.5" ive been wanting..
being on a limited budget DOES suck. im using the MARINE cam however, because of its 114 LSA its better for my blower.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
