HELP! Th 700 Lock-Up wireing
Old Jan 10, 2003 | 04:39 AM
Tobbe tha Swede's Avatar
I run a th 700 tranny mated to a non computercontrolled 408" smallblock with Holley and would need a way to manouver the Lock-Up.
1. Does anyone know how to wire the Lock-up for manual engage and disengage with a toggleswitch ?
2. Would I need to do any other modifications for a hassle-free ride?
Thank you,
Tobias Pervik, Sweden
Old Jan 10, 2003 | 04:48 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
here is the tech article
https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Old Jan 10, 2003 | 04:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Välkommen!
The TH700 need 12 v to lock up, you have a 3 wire connector on the transmission. You need the two outer ones on the connector. The front should get 12v when ignition is on and the back would be its ground. Just put a switch on any of them......
or you could put a switch to the ALDL like above if you have stock harness in the car.........
Swedish forum www.tacs.nu/forum
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Bryan F
Aug 27, 2015 07:28 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
