TH700 and LS1
Old Jan 12, 2003 | 01:45 AM
87TA 305TPI's Avatar
TH700 and LS1
would my TH700r4 trans bolt up to an LS1 engine? i have a friend selling an LS1 from a 99 trans am with only like 10k miles on it so i would hate to pass it up, only $600 for the complete engine. so if anyone has any info for me lemme know. thanks
Old Jan 12, 2003 | 08:13 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
No it won't. You'll need the newer 4L60E and a computer to control the shift points. Well, if you install a LS1 then you will have that computer then anyways. I'm still waking up.
Old Jan 12, 2003 | 01:26 PM
i knew i would need a new computer but the transmission will NOT bolt up? will i have to get a new driveshaft and rearend to fit the trans too?
Old Jan 12, 2003 | 02:26 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
The TH700 will NOT bolt up. You will not need a new driveshaft to fit a T-56 and the 4L60E I am not sure of the length. Nor will you need a different rear. But many more complications will come with an LS1 swamp that will add to the cost.
Old Jan 12, 2003 | 10:08 PM
what kind of complications are we talking about here? i know the comp and wiring ill have to change, and the trans, motor mounts, and trans mounts and the trans crossbrace. any other big things you know of off hand? thanks
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
