Why wont any shops do this?
Old Jan 16, 2003 | 01:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
My transmission, the rare (never rebuilt) 82 700R4 (not original to my car mind you) is starting to get me worried about the cluches, its not slping at all and is in real nice shape considering all the goodies put into it. Anyways I talked to a few shops to see how much it would cost me to have them replace the clutch packs/steels and they wont do it! I'm getting a new tq converter and I think this would be a good preventitive cost saving measure since the transmission is comming out but all the shops told me no they wont do it that way, it's full rebuild $600-700 or nothing. I could do it my self but I hate messing with automatics. What gives??????????????????
Old Jan 16, 2003 | 03:12 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Because replacing the clutches basically requires rebuilding the transmission entirely anyways. It would be insane to pull the thing apart, replace the clutches, then slap it together with the old seals and O-rings.
Old Jan 16, 2003 | 07:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
One shop said they use to just replace the clutches for people but they ran into problems. I just dont want a local shop rebuilding my transmission I'd like to keep thier grubby figers out of it as much as possible. Ive only seen one tranny come out like it should from the local shops and that out of hundreds and it was a POS C4.
Old Jan 16, 2003 | 08:33 PM
ronterry's Avatar
Car: '94 Corvette
You know 'SSC' I would worry more about the seals then the clutches with tons of miles on it.
...and when you think about it, it's nothing to do the seals, and even bushings for the matter if your going in to do all the clutches.
It's like not replacing the bearings when changing out a crankshaft. I mean there right there, and thats the same with these trannie seals. There basicly exposed when pulling out the clutches.
Even if they did just change the clutches only, the price might only be 25 dollars cheaper.
Ron
Old Jan 16, 2003 | 09:34 PM
laiky's Avatar
see above, its dumb
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
