Will rear disc hardware fit drum housing?
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
There is a set of rear disc hardware off an 87 GTA on ebay. Every thing from the housing flange out. Will this bolt on a 91 drum housing? I know there is more work to a converson than that, but just curious if the parts change out. Thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Brakes
Rotors won't fit your axles. Outer diameter is too large.
Car: 91 Z/28
Engine: 5.0
Kinda what I thought.
If you had a complete disc rear, and didn't want to change the whole thing out, can all the parts, including axles be swapped out to a drum rear?
Car: Take
Engine: Your
Transmission: Pick
People have modified their drum housings to accomodate disc backing plates, but for the lackluster performance, and severe reliablity issues the earlier style rear disc brakes are notorious for, personally, I'd stick w/ the drums. If you can find some of the later aluminum PBR brake setups, then your looking at a decent upgrade.
sailtexas186548
Jan 19, 2016 12:21 PM
