W/C T-5 trans yoke ?'s.
Old Jan 31, 2003 | 08:25 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Is the stock yoke stronger than the tranny? Guessing so.
Where can I get a used one? If it is good enough.
Where can I get a new/aftermarket one? If the stock one is weak.
Old Feb 1, 2003 | 07:17 AM
ede's Avatar
ede
not sure but i'd guess the yoke off anything with a t5 would work. i'd aslo guess anything a 700r4 would also work. along the same lines i'd bet just about any yoke from a gm car or light truck would work. even if you had to shop a little for a u joint i ithnk about any yoke will fit. try gm parts or a bone yard for a replacement. you'll break a lot of parts long before the yoke fails.
Old Feb 1, 2003 | 07:34 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Found out the stang is one spline off so can't use that. Will make some calls to junk yards around me.
Hawk312
Aug 22, 2017 08:55 PM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
