auto to manual swappers inside please
Car: 1989 IROC-Z
when you all cut the whole in the floor for the shifter, how did it look. how did you seal it etc.?
anyone have pictures of it?
care to explain the whole process of making it look good.
I didn't take pics but it's pretty easy to explain. I used a Sawzall w/ a metal-cutting blade, filed down the rough edges, then painted w/ POR-15 to keep any bare steel from being exposed.
To size the hole, I mounted the trans and jacked it up slowly until it was touching the trans tunnel. I marked around the shifter housing w/ a carbide-tip sharp punch, lowered the trans, and dimpled the sheetmetal at the four corners so I could see the shape from up top (not necessary if you're sawing from under the car). I added ~1/2" all around to ensure there was room for movement due to engine torque and whatnot.
Car: 1989 IROC-Z
hey kevin.
thanks for the reply, thats pretty much what i did. i did the swap back in the summer, but i just feel like I did a hack job on that part, and wanted to know what some other people did, and try and get ideas how i can maybe fix it up to look alittle more "stock" appearing. i hope its not beyond repair.
thanks again bud!
thanks again bud!
Car: 1989 IROC-Z
Originally posted by kevinc
Not planning on disassembling my console any time soon, sorry.
i can understand, mine was a bit of a pain to take out.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
