Drive and Driven gears for 3.42 to 3.73 swap
Old Feb 6, 2003 | 02:29 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Hello All,
I currently have a 3.42 posi in a '91 Formula with electronic speedo.
I have a set of 3.73s I am going to install in same car next month.
I am trying to find out if if anyone knows:
1) what the speedo gear combos are for the current 3.42 and
2) what the speedo gear set combos need to be for the 3.73s to keep an accurate speedometer ?
thx in advance,
RP.
Attached Thumbnails Drive and Driven gears for 3.42 to 3.73 swap-firebird9.jpg
Old Feb 6, 2003 | 03:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It will be the same drive gear.
Check your odometer. If it's accurate, then look at the driven gear you have now; count the teeth; get one with as close as possible to (3.73-3.42)/3.42, which is about 9%, more teeth.
Old Feb 6, 2003 | 08:00 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Here is a great link for speedo gears and how to figure which ones will work for you. It is near the middle of the page on right.
http://www.sallee-chevrolet.com/Chev...tallation.html
Old Feb 6, 2003 | 09:07 PM
vjo90RS8's Avatar
Car: 2002 Z28
www.700r4.com there is a calculator on their site
Old Feb 7, 2003 | 08:34 AM
palric's Avatar
still don't get it
I've checked the tech notes, done some searches, perused web pages.
There seems to be a diff between drive/driven gears on autos and T5s. Can anyone comment on this ?
eg: 15/41 on an auto vs. 9/22 on a T5 ???
Lost, confused,
RP.
Old Feb 7, 2003 | 09:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, the auto gears and stick gears are completely different, not interchangeable.
Old Feb 8, 2003 | 07:06 PM
palric's Avatar
ttt.
I am stuck the search engines are still down and I need to know how many teeth in the driven gear for my existing 3.42, and also for the 3.73s I am swapping in. Can anyone help out ?
thx,
RP.b
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
jharrison5
Aug 19, 2015 05:53 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
