Stock rear end gears for 92 rs., what are they
Old Feb 9, 2003 | 07:44 PM
croppy's Avatar
Car: 1992 RS
I am going to replace my rear end gears. I looked for some kind of ID numbers on the axle and punkin ball but I couldnt find anything.. What gears did this model come with, and do you think I should go with 3.73 or maybe 3.42?
Old Feb 9, 2003 | 07:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Do you still have the sticker inside the center console?
305s and autos usually got 2.73s.
Old Feb 9, 2003 | 07:59 PM
croppy's Avatar
Car: 1992 RS
Thanks for advice
I appreciate the heads up. But I am still wondering if that is a posi unit, and how much will I benifet from gear change.
Old Feb 9, 2003 | 08:03 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its possible that it could be a posi. My 'vert came w/ 2.73 posi.
There is usually a significant difference when you do a gear change. A step from 2.73 to 3.42 or 3.73 will probably put a grin from ear to ear.
Old Feb 9, 2003 | 09:02 PM
gearhead86's Avatar
If you're looking to see if its a posi or not,check the build sticker in the console. If its a posi it should have a G80 op code. I think that op code goes across the board for any Gm product. My car was originally a v6 car so it had 3:42s in it. Now that it has a v8 those gears are quite adequate for everyday use.
Old Feb 13, 2003 | 01:12 PM
croppy's Avatar
Car: 1992 RS
Still not sure
I looked for a console sticker and had no luck I also looked for ID numbers on axle and couldnt find any. Im pretty sure that they are 2.73, but I will find out when I replace them, hopefully this month or next. I am looking forward to seeing what a difference it makes. My tranny was just professionally built by a local guy I know and that made a nice difference. I am also adding a B&M megashifter and tranny cooler at the same time. Cant wait till spring.
Old Feb 13, 2003 | 09:57 PM
larry92rs's Avatar
Try this look at the R.P.O codes in the rear compartment in the hatch and the 9th row 2nd #down might be the axle code and if its 2:73 it will have the code GU2, but any way the codes will be in the hatch campartment door open it and on the door you will see the sticker that reads a bunch of numbers and in mine it was row 9, 2 down it had gu2.
I have a 1992 camaro rs lo3 273 rear gears
if that don't help I'm sorry then, good luck
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
