looking to swap in posi rear
Old Feb 22, 2003 | 12:12 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
ive got an 84' LG4 Z28 with a nonposi rear end. while the 3.23 gears are ok for my application, i would really like to swap in a posi diff to launch the car harder at the track. are there any posi rears i should be looking for that are a direct bolt-in? i was thinking of a 4th gen unit... it seems like a good choice, since all the LT1 cars came with at least posi and 3.23s. thanks in advance
BTW- i would like to keep the drum brake setup, any posi rears use these kind of brakes also?
Old Mar 6, 2003 | 04:16 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
if you want to keep your drum rear, why replace the whole rear when you can just buy a posi unit? easier then dropping the rear and installing a new one, not to mention connection all the lines bleeding brakes etc....
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
