Swap rears off 83 Berlie to 91 RS?
Old Mar 3, 2003 | 07:12 PM
TBIfly's Avatar
I just bought a running 83 berlinetta for $400, with the LG4. It has a 3.23 rear on it.
My 91's rear seems to be going out, evertime the gears are engaged, i hear a clunk clunk, and there is a considerable amount of backlash when im under the car and manually rotate the driveshaft clockwise-counterclockwise. I may be wrong, but im sure im losing my rearend soon.
QUESTION: Can I just remove the complete rearend off my 83 Berlinetta with the 3.23's and directly bolt it on in place of my 91 rearend with no mods?
What kind of time am i looking at?
3 hrs to remove both rears? about 4-6 to install both?
I think Im going this route because id rather swap rears with only the cost of the time to do it myself with help, and for the gear oil.....than to but $200 gears and have a shop install em for me.
thanks guys:lala:
blain
Old Mar 4, 2003 | 05:36 AM
ede's Avatar
ede
should bolt right up, only problem area might be brake line fittings, not sure if all were bubble flared or not, but and adapter can fix that easy enough.
Old Mar 4, 2003 | 12:44 PM
Scott C's Avatar
Seriously consider changing the fluid in the 83 rear before you bolt it up. It'll take 5 minutes, but will insure longer life!
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
