Torque converter misalighned
Old Mar 11, 2003 | 06:27 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
When I redid my motor and installed my trans I did not have the torque converter in the trans like it supposed to be and when I bolted the trans to the engine it put pressure on the converter, will this hurt anything. Cause I have a wierd noise coming from the car now that I did not have before, not sure if it is coming from the trans though. When I give it gas sometimes it makes like a "tin grinding noise" sounds wierd.
Old Mar 11, 2003 | 06:31 PM
Breadfan's Avatar
thats not good . If you didn't have it to the trans all the way and bolted it up , you might wanna take the trans out look at the pump and the input shaft . Then look at the convertor . The convertor should lock into place 3 times , turbine stater pump .
Old Mar 11, 2003 | 07:13 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Definatly not a good situation. If you are hearing noises, then the damage is already done. You should probably take the tranny back out and dissasemble the pump. A majority of the time, the pump rotor breaks and you may have cracked or broken the converter like this:
Old Mar 14, 2003 | 01:17 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Just to clear it up I don't know if it makes a difference but I did not start the car like that. I just noticed the converter did not spin and took it back off to align it.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
