Drum to Disc rear swap
Old Mar 31, 2003 | 12:34 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
Have an 86 camaro and an 85 trans am doner car. pulled the 9 bolt disc from the TA and want to swap it into my camaro. what exactily do i need to change? thanks
Old Apr 2, 2003 | 01:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
drum-disc swap
I swapped a rear disc axle assembly from an 84 berlinetta into my 88 bird. You must obtain the correct proportioning valve (sits under the master cylinder), and a different master cylinder (different check ball inside I believe). The brake line T is in the same location, so no changes to line routing are required. If you want your parking brake to function, new cables will be required (they are of slightly different length). You should be able to use the drum e-brake equilizer (the gadget that the cables hook to under the center console on the underside of the car). Hope this helps...
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
