1st to 2nd lag
Old Apr 1, 2003 | 01:30 AM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
1st to 2nd lag
How do I fix this?shift kit or something in the transmission.its starting to get longer and longer.my car has 145,000 miles on it when I got it,maybe time to rebuild?Thanks
Old Apr 1, 2003 | 11:51 AM
Pro Built Automatics's Avatar
If you do not want to rebuild it now, then add the Corvette servo for a start, and maybe the .500 main boost valve if that does not work. This is could be a temporary fix.
Old Apr 3, 2003 | 05:41 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
This worked well with my transmission for a while. Like Pro Built said, it is a temporary fix. My transmission died today. I may be calling Pro Built for a new transmission today.
Old Apr 3, 2003 | 10:30 PM
Momar's Avatar
One of my friends has a car that does this. It has done it since he had the car. He was told it was rebuilt and has a shiftkit in it. It seems to shift pretty firm unless he is at full throttle. I know that if we set his tv cable we can get it so it is not nearly as bad or not there and it shifts at the right rpm, but after a while it seems to move one notch or something. It never completely goes away, but is better right after we reset the tv. What I was wondering is what is this a symptom of?
Ben
Old Apr 3, 2003 | 11:02 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The problem that I had with my car was that at WOT it would not shift from 1-2 until about 6000 to 6500 RPM. Sometimes it still wouldn't shift until I let off the gas and then punched it again.
Old Apr 3, 2003 | 11:05 PM
Momar's Avatar
Yeah, thats what his does, but if we set the tv we can get it to shift closer to correct. Driving next to him when he is at full throttle kind of sounds like he is driving a manual because he had to let off of the gas lol. I was just wondering what the problem is that causes this.
Ben
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
mfp189
Sep 27, 2015 09:25 AM
tuningnewb
Sep 23, 2015 07:06 PM
